the dash makes an odd sound. Any one experienced similar?
"Odd sound" suggests one (or more) of the climate control actuators need resetting. Can't see how that would affect the city steering though.
Could try the CC Self-Learn procedure:
The self-learning procedure must be carried out using the Examiner (automatic procedure) or following the instructions given below (manual procedure).
1. Switch the ignition key on and within 40 seconds press the AUTO and MONO buttons simultaneously and keep them pressed.
2. After a few seconds a figure will appear in the left temperature display and decrease from 05 to 00 indicating the remaining time before the start of the procedure (keep the AUTO and MONO buttons pressed).
3. When the left temperature reaches the value 00, releasing the AUTO and MONO buttons will initiate the procedure lasting about 40 seconds.
4. Entering into local fault diagnosis, at the end of the procedure, the right temperature may display the following values:
00 = SELF-LEARNING taken place with OK outcome.
01 (flashing) = SELF-LEARNING taken place with not OK outcome
02 = SELF-LEARNING in progress
03 (flashing) = SELF-LEARNING not completed
The self-learning procedure does not take place if the AUTO and MONO buttons are released before the left temperature reaches zero.
The control unit makes the left temperature flash if the self-learning has not been carried out or if the result is not positive.
