Copied from Elearn for Stilo 1.6 petrol
The manual procedure and the teser procedure for re-initalising the electronic ignition/injection control unit is shown below.
When the car is first started, carry out the following operations whenever the throttle body or engine management unit is replaced.
During this procedure, from the moment when the instrument panel is supplied with power until the end of learning, do not press the accelerator, brake or clutch pedals.
Manual procedure
Turn the ignition key to ON position (engine off)
Wait 60 seconds, the time required for the control unit to check the throttle body's internal spring and the butterfly's maximum/minimum angles.
Turn the ignition key to the OFF position
Wait 10 seconds, the time required for the control unit to save the learnt values in EPROM.
After carrying out initialisation, the engine control unit may be deactivated (battery disconnection) without losing data.
I didn't touch any pedal, did I have to press it? I didn't touch anything after the book
