Has anyone ever changed the engine crankshaft oil seal (on a 115bhp JTD) - the one at the flywheel end, not the one at the cam-belt pulley end?
I'm assembling all the bits I need, in order to replace the dual-mass flywheel - and the rest of the clutch/slave as a consequence. Unless my oil seal is immaculate (206,000 miles original factory Fiat item, so possibly not...) now looks like a once-in-a-lifetime opportunity, if there's a low likelihood of everything turning ginger.
It looks like the seal just passes over the input shaft.. so it's a case of "threading it on" and bolting it down, rather than pressing it into a small recess (as driveshaft seals.. which always turn into a ball-ache, for me.. ).
Is it that simple, or is there some tricky gotcha/that wrecks the gasket so you need to buy two..?
Ralf S.
Ralf S.
