Hi,....
+ attached files
Hi,....
+ attached files
Thanks for the info.
What symptoms do you have and did you get it sorted?
Long story (+2years) short, my punto has a kind of fine hesitation and power loss all the way of rev.
My readings: no error codes, but total Fuel Trim at idle = around - (minus) 110%, which confirm the symptoms.
My actions: all the list attached for rich conditions already done (parts changed or tested), except a specialized test for the TDC (top dead center of timing). Which I intend to do next week.
Others: cleaned or replaced all the earth points, tested another virginised ECU. And....nothing.
So, I'm interested for any causes for extremely rich conditions, without error codes.
If you're so kind to keep us informed about the resolution, I will be grateful.
Also, I'll publish my findings, if lucky.
I'll publish in few days also my reals readings for all the sensors implicated in injection process.
I also hit -100% at idle and when pasking the car inside(start and idle her into her parking)I always pick up a strong fuel smell hence -100% fuel trim.
I checked grounds and vacuum leaks etc and all is ok.
Lot of answers in my head...i'll try to give the most important, according my level of knowledge ?
Me, I was a part changer, but I do not recommend to others.
What I recommend: testing every single part before buying a new one. I have a box full with sensors for ignition, changed but not faulted. I'm afraid to make a sum in € ?
Back to your car, I'll concentrate to the facts that I retained and the order I would take action. Still, the accuracy of understanding for each of us is a unknown variable...
1. TPS shows about 5% at idle. Not sure if normal, I was pretty sure it should be 0%.
How can affect the fuel trim? TPS is indirect part of the entry data for the predefined fueling map. The other is RPM.
More about: http://www.formula1-dictionary.net/map_fuel.html
My suggestion :
a) a good cleaning to throttle body with carburator cleaner. Be generous. Then need to re-learn the TB to ECU.
b) testing it with the multimeter. 30 min on youtube and you'll be able.
2. Hope that 'white staff' is not a sign of contamination of the oil with the coolant or vice-verse. It's mandatory to check, since that means a head gasket to change, with all the menu...
3. Identify and Check the ECU earth, both ends of the cable; for my punto it was very tricky.
Short solution: make a direct serious cable to the battery negative from one bolt of your ECU.
4. We have a confirmation: the smell in indoor parking confirmed a rich condition. Chances are the O2S1 to be good. Do not change it without testing. You need again a multimeter and about 30 min dedicated on youtube.
5. We can make a speculation: Because a reach condition enough time could contaminate the O2 sensor AND clogging the CAT, maybe this is the reason the last owner made a decat + tried to give more air to the engine with a sport filter.
(My cat was melted in the middle of the ceramic, been there also...)
6. Since we talk about sensors, it will be useful to list any single electric malfunction in the car. Then check if any fuse for that function is placed in the fuse box from engine bay, which is usually dedicated to injection. Tips: AC, interior fan, anything...
Others: We have different engines, so not so relevant, but I can rev to max (about 7000) with no load. Another speculation: maybe this is related to the 5% of TPS loosed at idle.
Sorry for this long post with condensate information , but not sure i'll have time next days to publish one by one.
Where can i get the tps update ?
Unfortunately, I can't help with specific details for stilo. Maybe there is a dedicated topic.
If 5% TPS is normal, next points should be analysed and excluded until the real fault is revealed.
Otherwise, you'll be forced to retake one by one all the suspected areas and testing them properly. I'm here now ?
Of course, the motivation, the budget and the intended ownership of the car really matters.
