Abarth L
- Apr 9, 2010
- 136
- 32
The wet compression test confirms you have low compression on cylinders 3 & 4.
It is also the reason you had smoke when you started. ( oil you used for the test, which had to burn out )
The noise you hear can be from what ever combustion air is passing.
When the car is idling and you remove the oil fil cap:
1. Are the oil coming out at standard idling rpm?
2. When someone ref the motor to about 2000 rpm, are there oil coming out?
If it is the rings as the wet test indicate, then you will see or feel oil coming out by the oil fil cap.
Make sure oil level is correct before testing this.
