- Apr 2, 2019
- 8
- 2
Hi folks,
My 2002 Stilo Abarth Selespeed has an odd problem, it started to happen years ago but only on rare occasions, but recently has got much worse. Starting from cold all the gears engage without any problem, then after travelling usually around 10 miles (sometimes but not always) a check light says "auto gearbox failure" followed by a very annoying warning chime! When I stop the car will be in 2nd gear and refuses to engage 1st, when I try to proceed, both 3rd and 5th gear will not engage. So I put the car into manual mode and if I get persistent with the paddle eventually it will go into 5th and if I'm patient in time will go into 3rd, but it will take sometime before it will engage 1st. Anyway, so after all that business (and getting people behind waving fists, wondering what the hold up is about) you can carry on your journey for the rest of the day without a hint of trouble - but then the next time from cold you get the same repeat of the problem! I really don't think it's the Solenoid because it's obviously thermo/temperature related, sounds like a fuse box or Relay problem - does anyone know where they are situated, I cannot find a diagram to show where they are - can any body help please?
