General Poor performance
NebulaStilo
Member
Hi
So my 1.6 16v stilo has following symptoms:
Poor acceleration
Misfire type of idle at times(revving dont work,keep pedal down then eventually engine will react to your foot on the gas,happens now and then)
Stalling at times due to misfire above
Car doesn't accelerate like it use to
Even when driving at a constant speed,it will have a sort of misfire,like one cylinder went and came back again
The speedometer jumps down to 0 and then back up to your current speed and is accompanied with above symptom(the misfire while driving)
The car ,when accelerating,does this type of issue: e.g. you revving the car in neutral but you rev till a certain rpm then pause,then go higher and pause etc. But happening quickly as you accelerate. Like the Car feels very lazy.
The speedometer issue happens on almost every journey and poor acceleration and overall performance is a constant.
Misfire doesn't happen always ,just a quik 'jolt' if you wanna call it that and then back to 'normal'
This is what I done to the car:
Replaced a bad ignition coil,all the others are still working fine
Replaced fuel pump
Cleaned map sensor
Cleaned throttle body
Replaced all 4 plugs
Replaced oil and oil filter
Air filter fell out as i pulled away from my driveway somehow and broke,I couldn't afford the whole box so I replaced with a cone filter and pushed it on the air pipe where the box filter was.
Replaced timing belt and tensioner and main pulley belt.
Check engine light burning
Reset ECU like they explain on the net(take off battery terminals etc. )
Sorry for my weird explanations but I miss how my stilo use to pull.
Please any help...
Did you do the things you done to the car before or after it started going wrong?
To me it sounds like you have a fueling problem. It's interesting that you changed the fuel pump (so when and why did you do that?).
Have a look at the fuel rail pressure (you'll need a garage with the correct tools to diagnose it). If it's too low (or not increasing when you have more revs) then that will give you the hesitancy and general lack of poke that you are experiencing.
Another option could be an ECU problem, since 1.6 has the ECU on top of the head, so it gets heat-damaged over time and the pins move/lose connections. This might be the cause of the speedometer "hiccup" and again, if there's an interruption to the fuel pump supply caused by the ECU, it would cause your symptoms.
Have you had any aggro' at all from the ECU ever? Have you moved it off the cylinder head (it can be strapped to the side of the battery by all accounts). Otherwise, have a look at the ECU stored codes (you'll need a code reader software/kit). If you have a lot of random and unconnected error messages, then that might point to the ECU.
Ralf S.
Thanks Ralf
I changed fuel pump when car started giving that hesitation
The problems started before I changed all these things.
However the speedo jump is from recent. Like in middle ish of this year.
Hesitation has been from start of this year.
I read about the ecu problem yes. Thats going to be my next change.
Where I stay,the road is gravel where you come in so I drive really slow. I use clutch control,now when driving on this road and the cars rough idle forces me to press the clutch in suddenly,then the engine would jolt from the rough idle and then a error message would appear and then disappear. Normally check engine appears
Ralf S.
I changed the fuel pump in july
It sounds more ECU related than fuel pump/regulator. I think the gravel path is jostling the car, which could be causing the ECU to move about and losing some connection.
A duff/weedy pressure regulator would be more apparent if you're in a low gear at high-ish revs (e.g. 3500rpm) but on a trailing throttle. If you then give it a large amount of throttle the car should accelerate strongly. If the car is running along okay at 3500rpm but then when you give it a lot of gas it responds hesitantly, then it's not getting enough fuel.
If it's randomly hesitating while you're driving along the highway at light or small throttle, then the fuel pressure is probably not the issue. If the ignition system is okay (you seem to have checked it already) and there's no poor earth etc. then it would point to the ECU. While you're waiting to check out the ECU, stick an extra earth lead from the engine/head to something metal on the car's body. You can't have too many earths.
Ralf S.
Thanks a span Ralf
I'm going to try that test later with regards to accelerating from 3500rpm
I have changed my plugs now as a precaution.
It still has a shaky idle at lower rpm as the car gets warm and idles lower. Higher rpm it's okay but rev the car and keep it at say about 2000rpm then the cars rpm would dip and come back up significantlt. higher revs it doesn't do that as bad,like very slight. Thats what I'm feeling as I drive along on the highway and as I accelerate from traffic light. The car is overall sluggish. 5th gear the car seems to pull better than rest of gears.
I have moved the ecu already
My old plugs I changed
If you accelerate really slowly (i.e. on a very light throttle) through 1000-2000 rpm does it do the hesitation around 1600rpm... but then once you've passed 2000rpm it behaves more or less normally?
If it hesitates on a very light throttle, when fuel demand is low, then that's not consistent with low fuel pressure... it would have be very low. Possible.. but less likely that other things.
Your old plugs look not too bad... maybe a hint of running too lean (fuel again) but I might be seeing what I want to see.
Have you stuck the beast on a code reader? A potential cause of generally bad/uneven running is a worn out MAF sensor (the one by the airbox) and/or a dodgy lambda.
The MAF is distinct from the MAP sensor. MAP usually sits on the inlet manifold to measure the manifold pressure. The MAF measures how much air is coming into the airbox, and its temperature.
I see you replaced a "MAP" sensor.. if you meant MAF then that's good (hopefully it was a Bosch one and not an unbranded one). If you really meant MAP, then the MAF might also be one to replace. It's a bit dear for a Bosch one, so maybe leave that till last. MAF failures sometimes (but not always) give an OBD error code, which can be read.
If your car does the hesitation most at ~1600rpm and idles a bit lumpy especially when cold, then that's classic lambda sensor. The lambda has a heater circuit to keep it hot at low rpm, and the heater turns off when the revs reach about 1500rpm.. so if it's failing, it notices when the heater circuit turns off and that throws out its readings. If you can see an OBD error anything remotely related to the lambda, then change it.
As above, buy a Bosch or NTK one, with the plug attached. Cheaper ones only have bare wires which you have to splice in to your existing plug. Unless you are the World Champion soldering King of South Africa, a poor join can cause some electrical resistance which the lambda interprets as a "situation" in the exhaust, so it starts reporting incorrect readings. A lambda with a built in plug gets round that problem.
Ralf S.
Haven't stuck it on the code reader yet
Please send a pic of your MAF sensor.
I dont see mine under the hood.
My airbox fell out and there is no wires running there.
I stuck a cone on the pipe in mean time.
I listen to the car under the hood at idle. It sometimes dips (uneven idle) then the filter sucks air like a vacuum.
Please show me what this part looks like so then i know if I must buy a new box and MAF
I read that my 1.6 model doesn't come out with one?
Should I change my airflow pipe and cone filter to standard box?
Your car must have a MAF sensor. They were part and parcel of the emissions equipment when catalytic converters were introduced.
Mine is an inline one, separate from the throttle body. It sits between the airbox and the turbo (my car is a JTD) but your 1.6 will have one similar, either between the airbox and the throttle body (usually right next to the throttle body), or it will have one that slots into the throttle body itself.
I have attached a picture of what mine looks like (this type are all quite similar) and there's a picture of the 1.6 Brava (same engine family as yours?) type, that slots into the top of the throttle body.
If the airbox fell off then that doesn't bode well... but the cone filter itself shouldn't affect how the car idles and runs. As long as there are no induction leaks past the throttle body, the MAF will measure whatever air is getting in, however it's getting in (even if you had no filter at all) and it ought to compensate accordingly.
Ralf S.
Hi Ralf,
I have the second photo yes. The one in the air intake. I took that out and cleaned it. Cleaned throttle body too (both sides)
I do not have the first one however,the one that looks like it fits on a pipe.
There are no loose connectors laying around too
Hi Ralf,
See this where the pipe and the filter meet. Its not a snug fit and its bending the pipe.
When i took the pipe off,the car seem to run abit smoother.
[ame]https://youtu.be/he7yafNT3yg[/ame]
Link to a video of how my car sounds
Thanks a span for the help.
Anybody can tell you that you have all kinds of engine failures stored in the car's computer. Why don't you read out the codes? We can't help, if you are unable to check basic things. I told you at another topic, that check your injectors (at the connector, with a multimeter - 20 second job)
You ignored me. I'm sorry, but if you really want to fix the car, show some efforts.
Not all of us have access to a multimeter.
I'm living in South Africa where things are damn expensive and I don't earn alot of money.
The car is the only car between 5 people in 1 home and it's ALMOST ALWAYS driving. Petrol is expensive and thats where my money goes.
I can get diagnostics done and buy a multimeter but then I won't have groceries in my house.
Try living in South africa with this broken government 1 USD won't even get you a litre petrol.
I must borrow a multimeter whenever this car is not driving which is never
I'm sorry mate, it's not easy, but you have to try something e.g. borrowing at least a generic OBDII scanner to initiate reading out the codes - which would (or could) lead you finding the culprit, so you wouldn't have to blindly replace unnecessary stuffs and spending money on things which are actually working OK.
Anyways, before that if you have the chance to somehow fix/restore your damaged original airbox + filter setup, try that one (-> you noticed when fiddling with the cone filter/tubing, there was slight change in the engine's behaviour).
2nd as Ralf already told you; add an extra earth cable (and check your original earth cables - if needed, clean contact points. For example on the alternator - mine was especially crappy there, engine was cutting out thanks to that exact grounding point).
ECU is moved - excellent, that's an important step to avoid any further degradation to the solder joints on the PCB.
Check the cables and connectors for the 2 lambda sensors. Clean it with contact spray, if possible.
Hopefully you can find what's causing your Stilo to misbehave!
I can't find a decent view of the 1.6 intake system.. Even on ePer the MAF and/or MAP seems to be pretty elusive. Ahhhh
There could be just a single sensor but in that case I would expect it to be the MAF. If the plug-in style sensor you cleaned is on the *airbox* side of the throttle body (or in the throttle body assembly) then it's a MAF. If it's on the engine side of the throttle body (or on the inlet manifold itself) then it's a MAP.
It's only really important if you have both and you only cleaned/replaced the MAP.. since the MAF has a bigger effect on how the car runs. If you have just one sensor (the MAF) and that's the one you cleaned then don't worry about if you also have a MAP sensor.
I'm assuming for now that your sensor is the MAF and it's on or next to the TB. You said somewhere that you replaced it, which is good... but lately you said you cleaned it. If the MAF is knackered (and it could be, judging by the lights in your video) then cleaning it isn't going to help.
A MAF gets covered in grime but has a heater to help burn some of it off. If the MAF was just covered in oil and grime then cleaning it would help but if (for example) the heater circuit burns out, like a light bulb.. then polishing the bulb isn't going to make it shine. You would need a new MAF.
If money is tight and MAFs are expensive (don't buy a cheapo MAF.. they usually give strange readings and fix one problem but cause another) then try to track down a second-hand one. It's handy if you know/chat up any other Stilo owners with a 1.6... see if they'll lend you their MAF, just to see if it makes any difference. If another MAF changes nothing, then you know it's not the MAF.
The airbox/cone is not ideal but it wouldn't make the console lights come on or the car run erratically. It would still work out how much air is getting in and meter the fuel to match. It might have the power of a 1.2.. but it would still drive like normal (no hiccups, revs instability etc.)
But.. it's interesting the car "improved" a bit while you tweaked the air intake. That sounds like the cold draught woke up something down by the throttle body.. and the obvious candidate is the MAF.
If money was no object and code readers hadn't been invented yet, I would replace the MAF and the lambda sensor.. particularly if you or someone has used leaded benzina in the car (catalysts and lambda's don't like leaded petrol).
If you can borrow a code-reader or find someone who has one, then it would be worth clearing the codes (you probably have the full set by now) and seeing which ones come back.
Meanwhile check the battery earth and stick an extra earth on it... (the alternator earth sounds like it could be a good place to start with). Earthing wire is not too tricky to get hold of - go to a scrap yard and have an old battery earth strap off any new-ish car that you find there.
I suspect the beast has a couple of different problems (and it may turn out to be an ECU fault) but we can eliminate some of the easy ones first.
Ralf S.
