Old 16-08-2019   #1
tessiedog has donated!
Some kind of electrical fault?
Hi folks
Latest in what seems like a constant stream of faults with my ageing Stilo (1.4 16v), but this time something which has put her off the road.
Changed the dipped bulb on the passenger side, usual method for me - remove battery, loosen off the battery box so that it can be moved a bit to get into the bulb etc, changed bulb, put it all back together again and then... ...... won't start. Starter turns engine fine, but no sign of even wanting to fire up and also nothing else electrical works including no lights, nothing on the dashboard, nothing. Only other thing happening is constant high pitch noise and intermittent clickety click noise which seems to be coming from the ecu - this even when the key's not even in the ignition.
Any ideas at all?
Tia.
tessiedog is offline Reply With Quote Quote
Old 16-08-2019   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Some kind of electrical fault?
Hi @tessiedog,
Most likely cause is you have broken an already weak connection when removing the battery. the chassis "earth connection is most likely. Try connecting a jump lead from battery negative to the chassis /body - NOT the engine. If that fixes it check earth cables. If it doesn't carefully check all the cables (and fuses if there are any) on the positive connection. Check all the visible length, not just the battery end.
Robert G8RPI.
Thanks Mytheroo, tessiedog thanked for this post
Likes dukebus, wody21 liked this post
g8rpi is offline Reply With Quote Quote
Old 17-08-2019   #3
Quote Originally Posted by g8rpi View Post
Hi @tessiedog,
Robert G8RPI.
Dead right, it was a loose earth (the one under the battery box)! Got it, and now up and running again. Thanks so much for your help.
Likes dukebus, wody21, g8rpi liked this post
Grande Punto Electrical fault? Vbafiat Newbie Central 1 01-08-2012 10:22
electrical fault kenny FIAT Boo Archives 1 02-04-2008 12:17
(T) Electrical Fault matthew.raine Tempra 3 01-02-2008 17:53
(G) Electrical Fault Please Help HAve Tried Everything maranzano Punto (Mk2/2b) 2 05-04-2006 16:15
Electrical Fault John FIAT Boo Archives 1 25-03-2002 22:59
