Old 30-07-2019   #1
Macedonia
what is remaping
What exactly is remaping ? What does remaping on our cars? I need more specific answer.
What is turn off, what is turned on, what is increased, what not etc...
Also, is this a good idea to remap my car with those symptoms:
https://www.fiatforum.com/stilo/475157-stilo-jtd-115-problem-need-help.html#post4491516
zugreveles is offline Reply With Quote Quote
Old 30-07-2019   #2
Croatia
Re: what is remaping
Remapping is essentially moding map which is stored in car's ECU. Map in ECU is controlling how the engine works. How much fuel,air and so on.. is given at the exact moment. Map is divided into sectors which control different functions. For example: first sector is for how much fuel is injected, second is for how much air is injected, thrid is for timing the spark plug firing... There are much more sectors which must be modified to achieve anything. By modifying those sectors you can change the quantity (fuel, air) or timing (spark plug glow) which is injected into car's engine.
In short, you gain or lose horsepower and torque (performance) depending what you want, also in many cases you will get better fuel economy but you will probably shorten your engine lifetime (that depends how heavily map is modified).
Also worth mentioning, car remapping can be divided into stages. For example, Stage 1 is map modifying only, Stage 2 is more aggressive map modifying and maybe fitting performance parts such as performance air filter or more powerful fuel pump, Stage 3 requires even more moding...
Some of the things you can turn off are: Vmax (max speed limiter), REVmax (max rev limiter), DPF off, EGR off...
By reading your post about the car problems I would advise you not to do any remapping on the car until you fixed all problems and errors. Car's engine and transmission should be in excellent condition before remapping.
Likes zugreveles liked this post
Own: Fiat Stilo Abarth ('01)
dox097 is offline Reply With Quote Quote
Old 30-07-2019   #3
Macedonia
Quote Originally Posted by dox097 View Post
Thank you, that was the answer i wanted to hear 🤘🏻
Old 31-07-2019   #4
Yes.. fix the car's problems first. That might solve the issues that make you want to re-map something.
The manufacturer map is not usually perfect but it always works. Re-mapping might improve one thing but there is often some other compromise
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
(Tu) remaping bubba77 Grande Punto 0 19-02-2017 21:10
I'm remaping my own car. Shadeyman Leisure Lounge 21 18-07-2011 02:39
(G) Is it worth remaping a 1.2 8v GP DelG 1.2 Grande Punto 12 04-08-2007 02:04
(T) ECU remaping smurfhead Cinquecento / Seicento 8 15-05-2006 08:39
