Thread Tools
Old 13-06-2019   #1
jim cooper has donated!
Timing belt cover, 1.4 16V
I want to check that the timing belt tensioner has been fitted properly (with fixed and moving tension markers aligned). Is it easy to just take off the plastic shroud to get a look at the tensioner?
jim cooper is offline Reply With Quote Quote
Old 13-06-2019   #2
Re: Timing belt cover, 1.4 16V
It may be easier if you partially drain and then move the coolant reservoir. There's not much room in there.
Depending on how much/what angle you want to see the tensioner at, you might also be better off removing the o/s front wheel and wheel arch liner too.
Ralf S.
Thanks jim cooper thanked for this post
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 13-06-2019   #3
It's a one piece cover held on by 3 bolts. If these are undone it looks like it should slide forwards to the front of the car. It seems to be cut out to fit either side (above and below) of the engine mount
Old 14-06-2019   #4
Aye! The biggest faff is getting a ratchet/allen/torx key in between the cover and the inner wing. The bolts are usually Torxes (an Allen key will undo them if they're not too corroded).
Ralf S.
Old 14-06-2019   #5
Just found out cover is a two piece affair. Undid the two bolts holding the top bit but couldn't get it off. Not sure where to pull or in which direction.
Old 19-06-2019   #6
The cover will just fall away when it's undone. It doesn't have any clips or other fasteners... so there must still be another bolt in there. Two doesn't seem enough.
One of them is usually recessed and in the middle of the cover, rather than just around the edges... so have a good feel around for any "wells" that could have a bolt at the bottom.
Ralf S.
Old 21-06-2019   #7
Finally did it. Just two bolts for the top half but I wasn't pulling hard enough to dislodge it the first time.
Likes Ralf S. liked this post
Thread Tools
(T) timing belt cover jimbojimwj Punto (Mk1) 6 20-11-2011 22:16
(T) 1.2 Timing Belt Cover Steven Punto (Mk2/2b) 16 15-03-2011 22:16
(Tu) Timing belt cover JOHNNYMACKMK1 Tipo (Classic) 1 29-09-2010 16:35
(T) Timing Belt Cover? ytareh Cinquecento / Seicento 2 05-01-2006 23:24
