For a petrol engine 140 - 160 PSi is perfect.. and your readings are right in the upper middle of that range, and all pretty much the same.
A variation of 10% between highest and lowest would be less good.. as would any readings closer to 100PSI.
Good engine. Keep changing the oil and it'll run for another 200,000kms for sure.
Ralf S.
