- May 23, 2018
- 33
- 64
Hello Everyone,
Does someone knows what you need to retrofit the factory alarm system?
Kind regards,
Bberg
Kind regards,
Bberg
Hello Everyone,
Kind regards,
Bberg
Probably just the alarm siren with built in control unit, front interior light switch with alarm control buttons and the bonnet lock with built in switch. Wiring connector for the bonnet lock switch is probably already hanging from the front wiring loom
Having wired it in, you would need to carry out the proxy alignment procedure to register it with the body computer.
If you plan on buying a second hand alarm siren unit, many of them have water damage.
Very likely a faulty siren. Open the siren housing and check for damage to the printed circuit board.
