Needed to replace my inner boot on the drivers side drive shaft. I didn't have a thin wall 36mm socket for the hub nut. So this is what I did.
1 Wheel off.
2 top strut bolt to the hub removed. ( theres 2)
3 cut off boot
4 pull top of hub towards you. The 3 bearing spline will pop out.
5 remove circlip from end of drive shaft
6 Put a small 3 arm puller on to get 3 bearing race of the drive shaft spline.
7 Clean up old packing grease
8 slide on new boot and clips
9 Put some grease in back of cup
10 replace 3 bearing spline back on driveshaft and replace circlip
11 put back in cup and pack with grease
12 slide new boot on and fix clips
13 strut bolt to hub replaced.
14 wheel on
I could have replace the wheel boot at the same time but it looked ok
1 Wheel off.
3 cut off boot
14 wheel on
