FIAT Auto Specialist Team
Thread Tools
Old 01-04-2019   #1
Brake lamp failure..linked to oil level reading?
Hi all. I have a 54 plate 1.9 jtd stilo estate that's been flagging up the old brake lamp failure fault. Now if I turn the lights on and start it or press the brake pedal and start sometimes it gives CHECK OK and it behaves. Now one thing that's certain to happen is if it gives an oil level check the fault doesn't come up but if no oil level check is displayed then the fail warning and triangle light come on. It also has a preheat fault but a glow plug isn't giving a reading on the old multimeter so hopefully it's just that. Any ideas if the oil sensor is somehow linked into the brake lamp warning or could it be a crappy earth that they share, although nothing else is at fault. All bulbs, connections are good. It's fitted with a twin electric towbar but they all seem fine. Cheers in advance
Chris1577 is offline Reply With Quote Quote
Thread Tools
(G) removal of high level rear brake lamp hawkenc Punto (Mk2/2b) 1 26-04-2018 12:56
(T) High Level brake Light failure Cog420 Grande Punto 6 20-05-2016 02:21
(T) High-level brake lamp. BigKev 500 10 17-07-2015 23:56
(T) Brake Lamp Failure vladof Stilo 56 29-08-2011 08:17
(T) Oil Level Sensor Failure welshman42314 Stilo 0 26-08-2011 17:09
