Hello, Sorry to start another post here but thought i share with you what i have found out.Well as u no cluster died and nothing worked so found a set from 1.4 stilo and installed in car and worked great,other than mileage everything fine.
so as the dead clocks were lying around i seen threads about changing dials and removing needles.So thought may aswell have a try,I am quite mechanical minded so had a go at removing needles which 3 came off perfect Speedo the spindle came out with needle.but carried on and got down to pcb board.
there was evidence of water/Condensation around led lights(whiteish) so gave both sides os board good clean with toothbrush and contact cleaner.
Then noticed the capacitor had a slight bulge at top so ordered new 1.
when it arrived i took old one out and soldered new cap in,Also re-soldered all pins for main plug and few other solder joints so nice and shiney again.
I put it all back together noting marks made in pencil where needle positions where.i re-installed in car to find it all working again great other than speedo not working,But thought result so i took cluster back out and went back to solder iron,I un-soldered the 4 pins for the speedo stepper motor and changed it from other set of clocks .Soldered the speedo motor into original clocks and put it back together once more,Now fingers crossed i re-installed into car and now it all works perfect,Just as it once did.
just thought be good to share as maybe there will be others who could save there self some cash.You have to be carefull yes with removing needles,By using 2 tea spoons small ones you put 1 each side at base of needle under the round plastic cover and use as a lever keeping both sides equal pessure and gently but needs some pressure to lift up,But remember to mark the position the needle rests at before attempting.
as we had spare set we had bit less to lose .So worth getting spare set cheap first.But well worth it if it repairs just as ours did.
With help from this forum and guides it was about medium difficulty,So long as u ok with soldering iron and not too heavy handed
But happy that original mileage back and all works fine .
So would definately recommend giving it a go if u in same situation.Lcd flickered orange and that was all at start.
Very pleased with myself and great turn out,Thanks Again
