Old 07-09-2019   #16
Dean
Zeewulf's Avatar
Zeewulf has donated!
Re: Fiat Stilo Instrument Cluster Repair Question
Quote Originally Posted by Davren View Post
I'm in Kerkyra until 21st and don't have MES with me to check. It will be somewhere in the instrument panel or dashboard section.
I used it several years ago after fitting an Abarth multi-colour instrument panel into one of my JTDs. One of the needles in the Abart panel was reading incorrectly, so I used the zero function to reset it. As I recall, all 4 needles slammed back to zero, then I had to switch the ignition off and on, then all the needles were reading correctly.
Will an abarth LCD unit work correctly in a JTD, as i wouldn't mind doing that to mine ?
Zeewulf is offline Reply With Quote Quote
Old 07-09-2019   #17
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by spkour View Post
Where exactly is that?
Just found an image I posted on the forum. It's "Value Reset" on the "Actuators" tab of the "Instrument Panel Visteon" section of MES.
Name:	MES Value Reset.JPG
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 07-09-2019   #18
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by Zeewulf View Post
As the Abarth instrument cluster is not designed for diesels, there's no glow plug warnng light (yellow coil) on it. Didn't bother me.... after you've had the JTD for a year, you know how long to wait for the glowplugs at various ambient and/or engine temperatures.
The Abarth panel shows varying oil pressures and oil temperatures on it's central multicolour display as 2 semi-circular bar graphs, so doesn't have a conventional oil pressure warning light. I tried several ways to hook the JTD oil pressure switch into it, but couldn't make it work. Ended up running a wire from the engine management ECU oil pressure switch output to a spare, red warning light on the cluster. The spare warning light has 120 written on it (speed limit for Saudi Arabian market). I opened the cluster and scratched the 120 off, so it just shows a plain red light while there's no oil pressure. Was tempted to mark it "OIL PRESS" with small Letraset.
Apart from the above, everything worked as normal.
Likes Ralf S. liked this post
(S) Binnacle/Instrument Cluster Question Pete145 500 (Classic) 14 25-02-2016 21:13
(T) Fiat Stilo 54 plate Instrument Cluster. rikkithemod Stilo 9 28-10-2011 01:19
