Hello,
I have a problem with the fuel pump.
She stopped working at one go.
I have no voltage on the fuel pump conector.
The connector has 4 wires, 2 wire pumps - no power. 2 wire fuel float - he has 12 volts
I checked:
- The fuse is correct. (F21 - 15A)
Now I have a question:
What is the fuel pump relay? (Maybe T10?)
How do I check the relay's correctness?
And.. If I disconnect the pump connector, need to have 12 volt power on it?
I checked:
