Technical Ventilation control illumination
Nickg101
South Wales
Could someone give me a few pointers on changing a bulb behind the ventilation controls? I unclipped the plastic piece below the controls then unclipped the bottom of the control unit cover, I was able to lift it up but it was still attached at the top :confused: - how do I remove the control cover to get at the bulbs?
Thanks for any help.:)
Er ive done this once shortly after buying the car, cant recall it being anything too complicated, just a matter of unclipping bits and peices.......you'll probably find you'll have to take off more plastic bits than you think you have to
Im sure thats probably not much more help, but at least you know it can be done because ive done it
Matt, thanks for the reply, I've taken bits off cars in the past, just wondered if there was any trick to getting this cover off, like I mentioned, it sort of hinges at the top (probably clipped) but I wouldn't like to force it:) something might break and I can't see the top clips because of the bottom edge of the stereo. Hmm - not really urgent as two out of three of the controls are illuminated.
