bertiebumblebee
I thought I would report on the reliability of my 2004 STILO 1.9 JTD
I have owned my "budget Maserati" for just over 18 months I only paid £210 for her with 6 months MOT ( how she could of had a MOT with the back bushes ,front arms etc being in the hair raising state they were I do not know).
I have travelled approximately 12000 miles in the car. I bought this car to keep down the mileage (and avoid winter salt) on my other car.
I did all the required work when I bought her (lots of it) and for the first 9 months no problems occurred.
I have also fitted cruise control and (wiring required from connector under battery tray/fusebox and stalk fitted. Then proxi alignment to get dashlight to work.
In the last 9 months I have had the following problems
ABS light coming on -- new ABS sensor fitted to one wheel . now o.k.
Passenger side wiper stopped working in heavy rain. -- Fixed by fitting 3 pound clip from Ebay. I believe this is one of the many quirks of the STILO.
Rear spring broken -- no big deal probably all the potholes. Now replaced. I believe springs are a common repacement item on the STILO
Battery replaced -- expected batteries die! STILO's need a good battery.
In the last 6 weeks -----
Rear caliper seized -- now freed off - also brake pads changed . I had already changed the other side rear caliper when I bought the car.
Rear door would not stay closed -- lubricated cleaned etc but worn out so new lock required. A bit of a rave to get door to bits but new motor and lock collected from breakers -- now fitted.
Random lights on instrument cluster ---- Cluster removed and sent off for repair (thanks yellowstilo) -- car off road 2 weeks while repaired but now back on and working ok. I believe that this is another STILO common failure.
Hopefully we can now have run with no problems -- fingers crossed. XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
The STILO has been quite needy when you compare it to the 2004 MGZT 2.0 cdti which is my other car and the Honda Jazz 2004 1.4 CVT which my wife owns. Indeed the Honda has had very little work in the last four years (one brake pipe and regular servicing only).
However I do quite enjoy driving the STILO and hope to be running around in her for some time yet.
There are still jobs to do, for instance she has done 117000 and I have no idea if or when she has ever had a timing belt and water pump.
The wheels do do with a refurb (unlikely to happen).
When I bought the car 18 months ago the following was the lengthy repair list --
Rear axle bushes (PITA I had to completely take the back axle off the car to do them)
Front arms replaced
Front droplinks replaced
One rear brake caliper changed - original totally seized and definitely not doing any braking. ( I did manage to free it off but it then leaked)
Rear pads changed - completely shot - should of been changed a long long time ago.
Front discs and pads worn - changed.
EGR valve clogged - this is probably why the engine light was on. This now been cleaned and then an EGR blanking plate fitted.
Engine light turned off and has stayed off.
Front nearside headlamp bulb changed (PITA)
Rear number plate light one fitting missing and screws for other seized solid ( they all do that sir) now all sorted.
Rear wiper arm missing - now replaced.
Oil trap on bottom of air filter smashed allowing unfiltered air to enter engine/turbo - now sorted.
Air filter housing loose and hanging down - refixed
Full service filters oil etc ( looking at the oil I think the last oil change was done while Pontius was still a pilot)
Multiple bit of trim changed/repaired including parcel shelf ,handbrake surround, and numerous others.
Radio not working - fuse blown - trapped wire sorted
boot lock seized - now freed off
Car absolutely filthy inside - how could anyone drive it around like that .
Security Code for car ordered from dealer to allow synch of key fob and proxi alignment.
many others that I have probably forgotten about
Front arms replaced
