General calibration throttle with FES
misu
Member
You can calibrate the throttle with the MES program, if you can help someone with the settings and where you can in MES. thank you.
intri în engine te conectezi și apoi ai meniul, info, errors, parameters, graph, actuators, adjustments, la adjustments Dai click și ai self adaptation reset si phonic wheel learn, pt clapeta selectezi phonic wheel!
Thank you
I have tried to calibrate the clamp with MES I have connected but I do not have the adjustmens option, but self adaptation reset not and, phonic wheel learn ... go reset if I run on -self adaptation reset-
