chuffyshunter
- Mar 29, 2015
- 7
- 2
Hi.
I have a 55 plate Stilo 1.4 with a problemo. I drove it around 90 miles today, got home, took the battery off the Stilo (not the first time) to move one of my other cars. Left a code saver on the car to stop spiking the ECU’s on re connection.
Went to start the car. Cranked and cranked. Eventually it started. No engine management light but the engine was running like a turd. And the throttle pedal isn’t doing anything.
There’s a video below of the car running. I’m not touching the throttle in the video. The revs jump up and down all over the place and it dies. I have tried 4 different methods I’ve found for throttle relearn. None of them have made a difference.
On my diagnostics (Delphi kit) the pedal is showing a percentage when pressed and there are no horrible spikes or unusual anomolies. And no fault codes
Any help is hugely appreciated! It’s my daily driver so I don’t have to use the Turbo cinq and the Discovery for driving around pointlessly!
Here’s the link for the video of it running.... youtu.be/AN-19IImap8
The video appears to have no sound but the Rev counter shows you the problem!!
Thanks in advance
Jack
Thanks in advance
Jack
