Chisel Chest
- Nov 30, 2018
- 6
- 4
In my sights is a Stilo Abarth with the selespeed gearbox. I would very much like to know how the selespeed performs...... as I have little experience of such devices.
The scenario is; we are exiting a fast main road on the slip approaching a small roundabout on an uneven road surface. In a manual, I#d want to use engine breaking (as apposed to breaks) for which I would have to change one gear down to flick the car through the RA. This would result in a momentary entry into the red...... So what does the selespeed do? Does it refuse to change down on the command of the driver ( a la RS6 1st series and many others) Or is the driver in complete control of the FIAT gearbox via the paddles?
Similarly, changing up under hard acceleration, does the box change the moment the upward paddle is actuated, still with the throttle wide open or must the driver lift a little to assist the upward change?
My experience so far with such forward thinking developments can only be described as moderately poor.
Any insight into this would be very much appreciated. Indeed. Chisel Chest
