Technical Clutch Kit
The Clutch on my 2007 Stilo 1.9 JTD Multijet 120BHP has started to slip in 4th and 5th gear, not when changing gear but when accelerating. Not throwing up any error codes so looking at replacing the clutch and as the car has hit 150,000 will replace the DMF as well.
My question is which Valeo Clutch Kit Full Pack should I buy from these 2
https://www.valeoservice.co.uk/en-u...etId=18911&articleLinkId=252795977&search=car
or
https://www.valeoservice.co.uk/en-u...etId=18911&articleLinkId=144853982&search=car
Both are 22% off today from the various Autodoc websites and don´t understand the differences apart from one is €50 cheaper!
Thanks in advance
The second one has a whole load of supplemental information such as the equivalent Fiat part numbers. If we knew your chassis number we could double-check.
Both clutches seem to fit up to 2008 so I'm not sure that the date alone is much to go on.
The only difference I can see is in the photos. The Concentric Slave Cylinder on my old bus (JTD) looks like the "tobacco pipe" in the second link... whereas the first clutch kit has a CSC with a flat bell-end on it.
The end pokes out of the clutch bell-housing so you should be able to see it, on top of teh gearbox, if you peer down the side of the engine.
Ralf S.
The chassis number is ZFA19200000653936. Will have a look at the Engine Bay when I get a minute. According to EPER this is my vehicle
2V - STILO F.L.L. 2003 (2003-2007)
192.7AL.4.0 - SW UP-ROAD 1.9 JTD 120CV 88KW E4-5P-MY.2006Engine: 5242132 Vehicle: 00646914 Manuf. date: 21/11/2006
SPECIAL VERSIONSW UPROAD MY 2006(LV46)M1.9 JTD CF4 8V 120HP 88KW(M88)VSW ACTIVE MY 2006(V35)P5 DOORS(P5)
The 120bhp motore uses the same clutch as the regular 1.9 JTD in 115bhp flavour.
The differences in the various clutches seem to be because of a change in the clutch and flywheel during the production lifecycle.
Motore 5114179 introduced in a new flywheel and clutch.
Motore 5448794 introduced a different clutch.
Your Fiat part number (for a clutch kit) is 55190585 and this number superceded 71748169 so anything with either of these numbers would fit.
The clutch/flywheel kit you bought doesn't list either of these numbers... but clutch kits come in different combinations of contents, so it's probably not worth worrying about at the moment.
The first kit is definitely not for you though.. it says from Motore 5448794 so it's the final spec' clutch, not the one for yours.
Ralf S.
