Dear Stilo gurus!
The current situation:
- my rear left spring is broken (still in it's place, but makes horrible noises), so I need a new pair, but...
The previous owner changed the front springs to Eibach 11-30-001-01 type lowered springs... Right now I am unsure what should I do. I am experiencing very annoying "rocking" on uneven, slightly bumpy roads when I'm traveling at between ~75-120km/h.
I'm hesitating, because if I buy two new original one, then I guess this rocking / wobbling will be still present. Should I try to find a proper lowered one for the rear suspension? What would you do in this case?
Thanks for your help in advance.
Mod: I forgot to mention, that when I bought the car with the old, unsafe dampers, the rocking was a bit even more serious, but in February 2017 I changed ALL shock absorbers... Those things are still working fine, it's not their fault.
