I'm at my wit's end so welcome all serious suggestions.
For the past 4 months I've been getting the dreaded ASR, Alternator, loose connection fault in my 2003 Stilo 16v 1.6.
So far I have:
-Replaced the ECU with a new one
-Checked all Earths
-Checked battery voltage and alternator charge
-Cleaned MAP sensor
-Cleaned all battery contacts
-Cleaned entire fuse box
-Checked wiring harness connection to ECU
And since that did not fix the problem:
-Died a little inside
I'm really hoping that you guys can offer some sage advice on what could be the problem. I've read so many forums on this d*mn problem and no one seems to have a solution. The strange thing is, sometimes it does the asr, loose connection fault, while other times the engine just cuts out dramatically with the engine light on. Two different symptoms of the same problem?
Thanks for the help!
So far I have:
-Checked all Earths
-Cleaned MAP sensor
