dtimmins1985
Established member
Afternoon all,
Hopefully someone can help me here.
Will be swapping my steering wheel out for a new one later this week.
It's the same as I already have, 6 buttons and airbag.
Would just like to know of any drama's i may encounter and will the car need a proxy alignment again.
Bare in mind - the only part in swapping is the steering wheel and it has 6 new buttons on it (my old one has 6 buttons too) - will be using the original airbag so no change on that.
I have checked eLearn and it says to disconnect the electrical plug from the clock spring - only the plug, not the clock spring itself (i was dreading having to do that ) - then its a case of removing the securing nut cover and undoing the nut, then reverse the procedure and line up the furthest reference mark where the nut goes with the one on the steering wheel (there is 3 marks, two close together and one further away, its the mark further away i have to line up).
Just want to check i have not missed anything here.
I dont want the dreaded airbag light and no horn (horn currently broken but its not the clockspring -the horn is literally just dead, all circuit is fine etc).
So - if anyone can shed any light.
P.S - if i will need to proxy align again then not an issue for now, will do that next month as i need to buy a new MES licence (no longer have my old laptop that had it on its been over a year since it was activated so not a chance in transferring an expired licence).
Any help appreciated greatly.
Kind regards,
Dan.
Kind regards,
Dan.
