Travis9599
- Dec 30, 2017
- 26
- 10
Credit to Yorkshire007
Seeing as the Stilo only has led bulbs to replace the dull looking standard ones and not units which are significantly brighter and give a much cleaner look, I searched for an alternative. Luckily Vauxhall Signum’s have LED units which are pretty much the The same size as the Stilo’s ones so I ordered some off eBay. All that was needed was obviously the LED units, some resin epoxy glue (as the screw holes don’t line up) and some plyers or some kind of tool to bend the power spades into the right shape to match the stilo’s. 20 minutes later and I was done, 10x cleaner, brighter and gives it a more modern feel and look.
