- Feb 18, 2013
- 168
- 118
Torque Pro
Torque Pro
HiBuy an ELM327 Adapter and you should see the values.
Hi
Please read the whole thread, the issue is the ECU not providing the expected parameter(s) rather than a connection problem. The OP has not responded to recent questions either.
Robert G8RPI
I have read the whole thread but it seems that its you that didn'tunderstand the question...
IF you use ELM 327 either the cheap one you can get STFT & LTFT with Torque Pro(android), or Car Scanner OBD (Windows mobile phone).
It works for me I tried it, have you tried yourself?
Please dont be so pro...
My Stilo is 1.2 16v with LPG fitted
ECU ME73H4F015
Torque Pro works fine, it indicates right values for Coolant temp,Air Intake temp, STFT, LTFT, RPM, Voltage, Timing advance, Fuel status Open loop/Closed Loop, Vacuum.
Sorry for that but in my Stilo it works fine and its very usefull to adjust LPG mixture.
But recently I fitted an LPG Ecu that connect directly to Stilo's OBD and reads the values for STFT and LTFT and adjust the right fuel mixture by adjusting the LPG injector open/close timing in real time.
