rossoneroto
- Dec 29, 2017
- 2
- 1
Hello, I have Stilo 1,6 16v, 2001 from 1 month. It was working perfect for the first two weeks and then started the common problem for this engine - lose conection, ASR failure, altetnator failure which as I understood the problem is related to the ECU. I watches the video with resoldering the pins of the ECU and paid to electrical engineer to do it.
The problem was fixed for 2-3 days but then appeared another one which I cant find a way to fix. One morning I started the car and it was working on 3 cylinders and a lot of white smoke was coming out of the exhaust (unburnt fuel), the injector was permanent open. I decided to bring the car to my mechanic, he was thinking that the problem is injector, changed it and the car was working fine for about 1 hour then engine fault came and the car lost 1 cylinder again. I bring it again to him and he said that most probably its the ECU. Now the car is working on three cylinders and there is the injector of cylinder number 3 is permanent closed or opened, it doesnt work on impulses, like it should be. I cant find any decision to the problem. I also bring the car to another service and there they also said its ECU but they can only resolder it which is already done.
So my question is, do I have to buy a new ECU or it can be fixed, if you have any ideas how i can fix the problem please tell me.
P.S
Sorry for my bad English.
P.S
