Technical Stilo 1.6 16V 76kW missfire
Pglock
Česká Třebová
Hi all,
nice to be member of this comunity!
For the start - I have a question.
My stilo 1,6 76kW (2004) is indicating MIL - trouble codes are P0300 and 0302 (sometimes 0303).
So, I replaced spark plugs and coils (all of them NGK, type as same as in the manual).
Condtions when it appears - highway speed (more than 4000 RPM for a longer time).
After some time (maybe 2-4 minutes) starts flashing MIL (sometimes for a few seconds, sometimes for a minute max). When it flashing engine has no power problems or vibrations.
So, Im thinking about replacing fuel pump or knock sensor. Is it good way or not?
Hi guys,
yep, I have replaced ignition modules and spark plugs.
Im thinking about ****ed lambda sensor - pre cat lambda. Now, It´s really cheap, so i have no problem with replacing it.
Stilo is nearly 90kkm (real), so maybe thats the problem.
Which brand would you recognize? Bosch, Magneti Marelli?
No, we haven´t.
We have autokelly and TecDoc.
Both of them (Bosch, NGK) are about 1000Kč, so it´s ok.
I will replace it.
Hi guys,
finally I have replaced the pre-cat lambda.
Now - better idle with less vibrations, better starts, engine runs smoother than before. I hope o2 sensor was the problem.
Removal and replacement was without problem. Original o2 sensor was Bosch, I have replaced It with NGK brand O2 sensor.
Price was so good - 1,200Czk with shipping.
Thanks for your help!
