Has anybody that has had a faulty instrument cluster ever had...
1. A shorting out type electrical sound coming from behind dash when the car is switched off? (it sounds like a cracking static sound)
2. Issues with the car stalling on tick over? Mine will tick over ok but as soon as you rev it it stalls instantly. Sometimes it will stall even without reving it.
What I am wondering is can a faulty cluster actual make engine stall/not rev ? or is it a different issue causing that. The fan comes on by itself and what ive noticed is if you touch flap in throttle body it will stop fan. I have cleaned throttle body.
