Mighty mouse
- Dec 17, 2014
- 2
- 1
Hi everyone,
We are having troubles with my son's 1.9 JTD 115 Stilo, that we bought to fix up so we don't know much about it's history. It starts fine, idle a little rough but it is a diesel after all. Doesn't smoke or knock.
After a few minutes it stops nice and gently and won't restart. I removed the fuel feed to the filter from the tank, and it pumped diesel with the lifter pump. I reconnected it and it started, so I put some clear pipe in the line to the filter. It pumped a few seconds and stops, the car starts fine and after 3-5 minutes it stops again.
The return from the low pressure ramp seems to over pressure the filter and push the fuel down the feed pipe from the tank... Is this normal or could their be a pressure reducing valve not working in the ramp ?
Thank you
Thank you
