Technical F06 maxi fuse woes
Abarth71
Been looking forums for answer to this...basically I left the car sitting (2004 stilo abarth ) for a month (was fine) so battery went flat. I got rac to jump it with a pack. Got home so removed battery to charge it. On replacing battery now car won’t start. Getting esr asr abs security loose connection warnings. Tried new battery still the same. One thing I have noticed that when I put ignition on the fan starts and runs constantly...if I remove f06 fuse it stops. Have tried swapping for another.
I have tried cleaning d4, Ecu connections, split fuse board and made sure dry.. think clue is the fan running but don’t know what it is :cry:
Anybody any idea ?.
Thanks for any help !
Yeh tried cleaning them..what I have discovered if I disconnect the coolant sensor loads of the warnings eg security, loose connection disappear..still esr and one other just...will try fitting new sensor and update.
This problem was a faulty ecu....fixed by the ecu doctor...really professional and fast ...very recommended!!!
