Old 02-10-2017   #1
"Water in Fuel Filter" error message
I am getting "Water in Fuel Filter" error message which literally flashes up for a second then disappears.
I suspect a faulty sensor, but just in case - how do I drain the filter?
I have a 1.9 jtd Stilo.
Thanks in anticipation!
Stub Mandrel is offline Reply With Quote Quote
Old 02-10-2017   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: "Water in Fuel Filter" error message
Disconnect the wiring connector at the bottom of the filter, then unscrew the water in fuel sensor to drain the filter.
Name:	Water in Fuel Sensor.JPG
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 02-10-2017   #3
I think the canister has a thumb screw at the bottom... but I've never carried put the process. Could be just undo, drain, tighten... with the engine off.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 02-10-2017   #4
Thanks Both, I'll have a go.
Replace "Fast Change Fuel Filter" - How? Quboffin Tech Talk 6 23-07-2013 10:11
(T) "Check diesel fuel filter" tappis Croma 21 10-07-2013 20:22
(T) Loose Connection Error Message Followed By Water in Fuel Filter Billy123 Stilo 1 09-01-2013 11:43
(T) error message "loose connection" smurf01 Stilo 22 05-05-2012 21:11
(T) error message BC: water in diesel filter Neo767 Stilo 25 23-05-2005 22:40
