Hi all,
I recently bought front and rear disc upgrade for my 1.4 active from MTEC. I've fitted the fronts with no hassle however, the rear discs i bought don't come with a bearing or center hub part. They are just the outer disc with a hole in the center.
My question is, do you transfer the bearing and hub part from the original disc onto the new one & if so how do you go about doing this? (they appear to be welded into position on the original)
J
J
