I've just replaced the near side rear brake caliper as it had seized, the pads were down to the metal. I've put in new pads and bled the system, after taking for a test drive i can hear rubbing whilst driving along, after about 10/15 minutes driving I stopped and felt the discs, both rear were very hot, the two front were fine?
Initially thought maybe i'd reset the handbrake too tight but pretty sure that's not the case as it takes 5 or 6 clicks before the car stops moving on a hill. Also, the brake pedal feels quite spongy, expected it to be a lot sharper following bleeding the system?
Any suggestions on what I should look at please?
thanks
thanks
