dtimmins1985
Established member
Afternoon all,
So i've been playing with MES again, but on the new stilo!
Its a 1.9 16v Multijet 16v 150, sporting model.
When i first drove the car it felt quick, it has a K&N OEM fitted kit and pulls like a train, its had cam belt kit done at 63k in 2015 and serviced regular since.
Each service has had 5w 30w silverstone oil put in.
It has been looked after and drives sweet when feathering the peddal but as soon as you tap it a little bit, all hell breaks loose and it lights up the tyres or wants to take you into the nearest curb or car, cyclist whatever.
Since this engine is the same as found in many Astras and in the same power figuers, ive drove them and this is nothing like them - its mind blowing, loves drinking the shell v power nitro diesel too, thought i was going to save on fuel but not really, only on a good run will i hit 55mpg, now im at 30mpg steady with a heavy foot loving the power, on a feather its around 45mpg.
I took some boost readings etc from MES and in third gear i hit what appears to be 40 PSI of boost...
is this normal for this car and turbo with a K&N filter... i think it may have been remapped but i want to be sure.
At idle it reads 1080mBar on manifold air pressure.
then you get this... see below, what i recorded with MES.
This is at Idle...
Engine speed
849 rpm
Boost pressure
1028 mBar
Then at full chat in 3rd
Vehicle speed
46.1 mph
Engine speed
3679 rpm
Boost pressure
2800 mBar
Desired boost pressure
2468 mBar
When converting mBar to PSI I get this:
Idle: 1080 mBar = 15.66 PSI
Full Chat: 2800 mBar = 40.61 PSI
Them figures look a bit off or way too much to me.
It has a Garrett turbo but cant see the model number... looks like Garrett **46 - the ** being unreadable.
Any ideas?
What boost is the 150 multijet supposed to produce stock.
This is at Idle...
Engine speed
849 rpm
Boost pressure
1028 mBar
Vehicle speed
46.1 mph
Engine speed
3679 rpm
Boost pressure
2800 mBar
2468 mBar
Any ideas?
