Old 01-03-2017   #1
Ireland
Exclamation I Need help with a Fault!! stilo 1.2 16v
Hello everyone i'm a new member as of about 10 minutes ago haha, the problem im having is while driving along or stationary there seems to be an intermittent fault where a loud clicking can be heard from the relay in the fuse box next to the steering wheel, when this happens all guages on the cluster drop off to zero and the engine starts to briefly miss. also if the headlights are on they will turn off. i have tried all the earths in the engine bay and still nothing has helped hopefully someone could point me in the right direction, thanks
Irishstilo99 is offline Reply With Quote Quote
Old 01-03-2017   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: I Need help with a Fault!! stilo 1.2 16v
Quote Originally Posted by Irishstilo99 View Post
How did you "try" all the earths in the engine bay?
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 01-03-2017   #3
Ireland
took them all off wire brushed the terminals and put them back on?
Old 02-03-2017   #4
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Check the multi-earth connections on the right of the centre console/tunnel near the ABS ECU, and under the right front wing.
Feel the relays to see which one is clicking.
Old 02-03-2017   #5
Ireland
Quote Originally Posted by Davren View Post
the main black relay in the fuse box is going mad
Old 03-03-2017   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Which one?
Name:	Dash Fuse Box Diagram.JPG
Old 03-03-2017   #7
Ireland
If the relays going mad pull it out check the pins for corrosion, clean and reinsert.
Likely culprits:
https://www.fiatforum.com/stilo-guid...connector.html
If you have corrosion then:
https://www.fiatforum.com/stilo-guid...#content_start
corcai is offline Reply With Quote Quote
Old 03-03-2017   #8
Ireland
Quote Originally Posted by davren View Post
which one?
t13
Old 03-03-2017   #9
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Relay T13 supplies the three door control ECUs and the sunroof (if fitted). It gets an earth via the body computer from the multi-earth point C15. I think that's the one next to the airbag ECU.
Have you checked that one yet, as I suggested above?
ID:	177952   Click image for larger version
Old 05-03-2017   #10
Ireland
yes i have completely cleaned every inch of the fuse box in the engine bay even cleaned every fuse and relay and sealed the whole unit in a case to protect it from any water but its still doing it so the next ones to try are the earths on the tunnel and the one inside the wing
Old 08-03-2017   #11
Ireland
electrical Problem still persisting..
my electrical problem is still persisting and im beginning to lose hope, after changing the body computer the fuse box checking all the earths and power even had a professional diagnostic technician pretty much put the car on a heart rate monitor its still doing it wev ruled out pretty much all the electrics between the front seats and the front grill and still nothing anyone have any random suggestions much appreciated thanks.
Old 09-03-2017   #12
Stilo Fanboy
nikiforos83 has donated!
Greece
Had exactly the same problem.
Probably you need to replace the temperature sensor housing inside the intake manifold.Check for coolant leak there that makes shorts to cables.
nikiforos83 is offline Reply With Quote Quote
Old 12-03-2017   #13
Ireland
Quote Originally Posted by nikiforos83 View Post
ill do that in the morning ill let you know how it goes
Old 11-08-2018   #14
Ireland
just to some up this whole thread the problem ended up being a cracked coil pack was earthing off the engine and causing an intermittent power loss problem.
Old 17-08-2018   #15
How bastard random is that?
Still... at least you have the beast back... and someone else might have the same problem and might not think we're all mad when we tell them to check the coils..
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
(T) fiat stilo 1.6 16v ele fault murphy2010 Stilo 2 11-02-2011 11:55
(T) Fiat Stilo 1.2 16V Engine Fault. please help! Lukesfiatstilo Stilo 1 07-11-2010 17:14
(T) Stilo 1.6 16v engine fault. Milsey Stilo 2 16-08-2010 13:02
