Hello everyone,
As you may know, there are severall topics about this problem, but most of them are from another actuator. Although they were helpfull at some point, it doesn't seem to fully help my problem.
https://www.fiatforum.com/stilo/240001-climate-control-airflow-issue-broken-actuator-2.html
My climate control doesn't seem to get the airflow where i select it to go to, so i start digging in the right side of the mid-console. This actuator does work.
So i moved to the left side of the cabin and found 3 more actuators which doesn't seem to work! When i set the climate for an example to the feed it doesn't move, but when i carefully rotate the white gears shown on the picture below i can feel it blowing the correct direction.
So my guess is when i replace one of those (or all of them depending on the following reply's) the problem will be solved, right?
I already tried to unscrew one of them but i can't seem to get to the screws. Does someone have any ideas? Or do i have to get rid of the entire steering wheel column?
