- Jun 17, 2015
- 109
- 32
Hi everyone,
So today I finally got round to replacing the broken door check straps. That went with no real hitches. Door cards off, speakers off and access through the hole was adequate to do it without taking anything else off. I learnt that tip on here. Forget the poster but if you read this and it was you...thanks.
But since completing the door checks. I've had a random problem turn up with the aftermarket Sony head unit that I fitted last year.
Again thank ls to Forum help, I went with the method that bypassed the ignition system but required you to turn the unit off and on manually. For me it seemed the better option. Thanks to the guide and advice on here, I completed the job myself and it's worked without any fault until today.
Now, I can't turn the unit on or off without the car ticking over. If I turn the radio off, I have to restart the car to get it to do anything.
Surely there's nothing in the doors that could be linked? We only had to disconnect the drivers side window switches. Nothing else was played with.
Answers on a postcard ?
