Since Gerrard is currently enjoying a holiday in my old mum's garage whilst I sort out the Body Control Module problem that's preventing the headlamps from working (MOT won't pass)... I have managed to ponce my sister's Renoort Megane as a temporary run-around even though (in her words) "it makes a bit of a noise".
True enough, the beast was making a terrific din - from what sounded like the o/s front driveshaft area.
I replaced the wheel bearing, since they are just a tenner and I had also just bought a wheel bearing fitting tool which I wanted to try out.. and that reduced the noise by about 30%..... but the beast is still half rumbling, half howling from the back of the gearbox/differential.
I'm not sure whether this could be one of the inner CV joints or the diff'.
Is there a good way to test the CVs to work out which one it is (or whether it's the diff)?
From memory the o/s inner CV is a JTD-like cup with a tripoid doodah inside it, whereas the nearside one looks different - just the CV boot bolted to the diff' with the driveshaft attached to it.
Ta,
Ralf S.
Ta,
Ralf S.
