Technical brake disc size 1.9JTD
redvtec
ordered some discs off ebay went to fit them and the caliper will not physically go on. its a 1.9JTD 3 door on an 05 plate
they are TRW DF4377 and say 24.2mm thickness. I'm now reading that this may have been a change over period? can some one give me the correct part number and size? I'm just looking for a standard disc.
thanks
It's 115 1.9 jtd the disc won't fit as its to thick. It would seem fiat changed the brake size on the 05 plate.
I can't see a different part number from 2005.
The brake disc part number is 46455892 and that applies to all 115 JTD's.. even the Sportwagon.
Are you sure the discs are in the right box or (unlikely I know) that the calipers are the correct ones? It has to be something weird....
My bet is that the discs you have are from the 16v (Multi-jet?)) I dunno if they are thicker but the beast has 140/150bhp... so could well be. Those are part number 46765546.
Ralf S.
I have ordered the correct part and returned the discs to the same supplier. the information on their ebay ad was incorrect. I've changed loads of discs and pads and thought I was going mad.
