Old 05-08-2016   #1
Ralph2 has donated!
New Selespeed clutch release bearing failed
Had a new three piece clutch fitted to the selespeed this week. When the mechanic started the engine, it appears the clutch slave cylinder failed. (resevoir draining fast, fluid from the bellhousing) He has not had the time to strip it all down again but we are a bit stumped as to what might have occurred. The possibilities seem to be:
1) Wrong cylinder supplied. Maybe careful measurement comparisons with the old unit would confirm/exclude this.
2) Clutch centre plate fitted the wrong way round. The guy is an experienced mechanic and although we all make mistakes it seems unlikely. Can be proven easily once stripped down again.
3) Faulty new cylinder. It happens but would be unusual I imagine.
4) Some procedure is required with MultiEcuscan before system is activated. Maybe pushrod clearance or something?
I read somewhere that the cylinder will almost certainly fail if it goes to maximum travel under full system pressure (40 bar plus), and the prevailing feeling is somehow this has happened.
Anyone have any experience/thoughts/advice?
Thanks.
EDIT: The next step we were about to undertake was to connect MultiEcuscan and bleed the actuating system, then calibrate.
You don't stop laughing when you grow old, you grow old when you stop laughing.
Ralph2 is offline Reply With Quote Quote
Old 06-08-2016   #2
Re: New Selespeed clutch release bearing failed
I've had similar happen to me before. Ex main dealer indie replacing the clutch on my Alfa 156 Sport, assembled it all, was about to put the box in place when the bear up gave in, completely fell to bits brand new out the box. delayed me by a day getting my car back as had to wait for replacement.
Registered Alfaholic
Current cars - Stilo Abarth (let's not mention the Audi)
Previous: Fiats: Uno, Tipo, Brava (1.8 ELX), Marea (2.0 155); Alfas: 156 (1.8TS), 166 (3.0 V6), 156 GTA, 156 Sport (1.9 JTD M-Jet), 159 Lusso (1.9 JTDM), 147 Lusso (1.6TS)
Artermis is offline Reply With Quote Quote
Old 13-08-2016   #3
Ralph2 has donated!
So here we are, still no further forward on account of the mechanic being on holiday! (well we all need a holiday)
Wednesday the box comes back out and we will know for sure what has happened. Meantime, is there any info anyone can impart about fitting the new clutch to a Selespeed? I was under the impression you fitted the new release cylinder, filled up the reservoir with cs fluid, switch on and connect up a laptop to bleed the system with MultiEcuscan. Am I right? The mechanic is having the tremors which is spilling his tequila...
Old 18-08-2016   #4
Ralph2 has donated!
Cylinder has failed, replacement ordered.
Old 18-08-2016   #5
Maigretnz has donated!
New Zealand
Quote Originally Posted by Ralph2 View Post
You are right. Bleeding is simple procedure. Just press a button on laptop.
https://www.fiatforum.com/stilo-guid...placement.html
Thanks Ralph2 thanked for this post
Maigretnz is offline Reply With Quote Quote
Old 18-08-2016   #6
Ralph2 has donated!
That's of great help, many thanks!
Old 23-08-2016   #7
Ralph2 has donated!
Thumbs down Re: New Selespeed clutch release bearing failed
Today the second brand new clutch slave cylinder was fitted.
Followed the instructions exactly as listed in the link above. Clutch bled fine, the EOM sequence went through like a charm. Switched off, switched on again, started the engine. Reconnected MES, 1st 2nd and reverse all selectable. Looking good, left on idle for a couple of minutes, when I got back in to try and move it, couldn't select any gears....
Pulling up the error code page I saw: Selespeed pump failed reading 'high' 'fatal' at the same moment as the mechanic said 'woah. switchoff!' and yep... here we are again, cs fluid pouring out of the bell housing exactly like last time. Well this cylinder lasted several minutes longer than the last one.
Now have no idea what is causing this. We still have the old unit (which was working fine) so I said next time the box comes out, fit that back. Meanwhile I'm off to order more cs fluid and hope the pump isn't broken from running with no fluid in the system.
Old 25-08-2016   #8
New Zealand
Perhaps the pump is not switching off when the pressure rises above setpoint.
Old 25-08-2016   #9
Ralph2 has donated!
That's possible I guess...but where is the sensor that tells the pump that...would it have been disturbed / disconnected to change the clutch?
Old 26-08-2016   #10
New Zealand
Not sure. Just thought it possible as I was getting pump relay stuck error when accumulator failed which was produced by high pressure being detected.
Probably attached to actuator block.
https://www.fiatforum.com/attachment...3&d=1430824949
Old 13-09-2016   #11
Ralph2 has donated!
Finally sorted. The problem was the Clutch pressure plate not seated properly. Glad to have the car back on the road at last.
Old 28-09-2016   #12
I'd sack your mechanic off, you NEVER start an engine after a clutch change without operating the clutch a few times before starting the engine, the big clue that this hasn't been done is the howl it makes as it shreds the release bearing/CFC, I hope that all who read this have learned something, there's no magic to selespeeds, just a complete lack of training amongst the UK dealer network.
smaky is offline Reply With Quote Quote
(T) Clutch + Release Bearing Chris RWatts Abarth Grande Punto 1 11-04-2015 08:39
(T) Clutch release bearing or not??? Brian JP Ducato 8 02-02-2014 08:21
(G) clutch release bearing... boilermansab Multipla 3 31-12-2013 18:00
clutch release bearing lee oakes-wilson FIAT Boo Archives 7 26-06-2010 16:49
Clutch Release Bearing Charlie FIAT Boo Archives 5 10-03-2006 13:02
