Hi All, I'm after a bit of technical help. While changing my alternator I noticed the flexible part of the front pipe is damaged and blowing, so I rang the local motor spares shop and their computer (based on my reg no.) showed a different exhaust front pipe section - so I didn't buy anything.
I bought the car second hand and I am wondering if it has had a full replacement exhaust from a newer model.
My car's front pipe bolts to on the engine end using a 3 hole triangular connector, comes along to a flexi piece, then continues on to a 2 hole oval shaped connector, then onto another box, pipe and back box.
all websites I have been on (and the shop) list my car as having a solid pipe, then some sort of flexi pipe as an extra part with a u-clamp fitting.
Should I be buying a front pipe from a 2004 model as this is the only one that looks similar to my own one.
https://www.dropbox.com/s/cyetp1d0viuo98v/2016-01-09%2013.05.47.jpg?dl=0
