General relay
General relay
which is the starter relay on a 2003 stilo
Hi, Welcome to the FF.
For all engines except the 2.4 with Selespeed gearbox, there is no separate relay for the starter motor, just the combined relay/engagement solenoid on the motor.
If you have the 2.4 with Selespeed gearbox, then there is also relay T20 in the engine compartment fuse box.
Sorry for commenting on a old post but I have a problem with my starter motor..... being that when I pull the stalk to activate my high beams the starter motor kicks in as well I can actually start the car by turning the ignition on and flashing my high beams was wondering if anyone knew the relay for the high beams????
I.m looking for 2007 1.4 petrol engine fuse box.
The fusebox is under the little hatch by your right knee.
If you mean you're looking to buy a new fusebox, then search eBay... there's usually a few Stilos being broken and I don't think the fuseboxes are very different between models.... though obviously the wiring and connectors and the fuses (which are on your car already) might differ,
Ralf S.
Ralf S.
Thanks for getting back to me anyway I had to take out the engine fuse box . So had it on kitchen table AND said clean it up on the inside so opened it up bits and pieces broken on the inside .as I to my wife this had been opened before and the soldering job was a very bad job done to all together or maybe it was a different fuse box all together mechanic said leave it there and if I felt like he could read it for me ??? ..so I said take it home myself and see could I do anything to it myself. So after 2 week I had seen advertisement parts for sale so I went off and got fuse box and 2 O2 sensors 60 euro the lot good value...gave the a quick clean put all them in place 👌 perfect no more lights on the dashboard // problems I had before I put in new fusebox and O2 sensors...on dashboard lights was red steering wheel engine light hand brake light abs light plus much .the car is going great once again .... thanks again everyone for your help...gerard Anthony...
