Thread Tools
Old 08-07-2015   #1
Central locking stilo
Just brought a 2002 stilo
The central locking does not work at all.
The fob led lights up but nothing from the car.
If I put the key in the door it unlocks but door handle does not open the car,so you have to turn the key fully and hold it there so the windows open so you can use the handle inside(very annoying)
Please could someone help me
diplomaticdom is offline Reply With Quote Quote
Old 15-07-2015   #2
Maigretnz has donated!
New Zealand
Re: Central locking stilo
Using multiecuscan software and cable you can match Fob to car.
You will need the security code for car. I got mine free from dealer.
Maigretnz is offline Reply With Quote Quote
Old 15-07-2015   #3
stilopete has donated!
I had this problem too but i could get into my car with the key, but in your case i think the rod between the handle and lock inside the door has come adrift or the clip has broken. You have to remove the door card and the window mechanism plate behind it to get to the lock it,s quite easy once you,ve found the problem and fixed it you,ll the able to get in the car easy. if you can get the key code from the fiat dealer then anyone with the multiecuscan software and the leads will be able to recode the remote for you... I can do it for you if you are not to far away but recoding the key will not fix the problem you have inside the door as that's fully mechanical
pete.....
stilopete is offline Reply With Quote Quote
Thread Tools
(T) Stilo Central Locking Fail stilopete Stilo 25 28-06-2015 13:17
(T) fiat stilo 2004 central locking bazzo Stilo 2 12-04-2012 17:55
(T) Stilo central locking/remote?? Bazzerd Stilo 2 18-01-2011 13:56
(G) Stilo Central locking problem Derr Stilo 9 02-11-2009 10:18
(T) Stilo Active central locking gayle Stilo 8 15-08-2008 20:22
