Technical After market Cruise control
Yes, that's the connector for the stalk.
Please, anyone who has working cruise control, could you check what does Multiecuscan display for Cruise Control parameters after connecting to the Engine management?
Hello, I have JTD with 6pin brown connector and 2pin counterpiece. So I wired the 4 other wires + 12V to my CC stick. Then I enabled it in MES, so it actualy lights the LED. All CC buttons are working, but when I tried it driving, it didn't work at all.
In MES I get P0703 Brake signal error every time I press the brake. The switch should be working fine and its connector has 4 wires.
What should I do? New brake switch?
OK, so I connected the pin A02 from BLACK D4 connector (purple/white in my case) to +12V on battery and now it works.
The question is - where should I get 12V from? The fuse box under steering wheel F35? And should I connect it back to D4, or can I wire it straight to brake connector? (that would be very easy)
