cab
Hi , I have a weird fault, when I put the air con on on my MW Dynamic I get cold air on the drivers side and hot air on the passenger side, can anyone help please
Ok I sprayed it with switch cleaner and ran it up and eventually it stopped. does it need setting up?
thanks in advance
You need to carry out the climate control self learn procedure. You can do it with Multiecuscan or manually as follows:
The AUTO and MONO buttons must be pressed simultaneously within 40 seconds of the ignition being turned to the ON position in order to active this procedure. A few seconds later a figure will appear on the display which will count down to indicate the time remaining before the start of the procedure. When the count down stops, release the AUTO and MONO buttons. Whilst the count down is taking place, the previous self-learning status is signalled on the display:
'1' flashes if the self-learning procedure failed
'0' indicates that the self-learning procedure was successful
thanks for that should this be done before or after reassembling.
After.
