So here is my problem.
New coolant sensor, new thermostat, new coolant and bled. Car nearly warms up but radiator fan is on from switching the ignition on which is over cooling.
The non air con Stilo 1.2 only has a slow speed relay and fuse. If I pull relay or fuse the fan stops. Multiecuscan shows the fan is always active. Engine temp sits at 71-76 degs (disconnect fan and temp goes to normal 80-85-ish).
I've cleaned up a few (apparently) related earth points but still the same fan runs.
So what am I missing? What could lead to this frustrating electrical issue.
