So sometimes my Stilo is not responding properly to the throttle for a few seconds, I suspect the lambda sensor is not giving a proper signal, but the issue is even worse when I connect the MAP sensor. Now I'm running without the MAP, the throttle issue is not as bad but still noticeable, and idle rpms are VERY rough, especially when cold, it almost stalls in intersections.
Should I replace both the MAP and Lambda sensors?
